twc's avatar
twc
sabnzbd causes high system load
Hi all,   Is it normal that sabnzbd drives the sysload up to 143? (as reported in the top right corner of the web interface)    I see three recently finished downloads (with "busy" spinners) in t...
  • twc's avatar
    twc
    Jan 23, 2017
    I think the NAS runs fine until sabnzbd begins repairing one of the downloads. So, I'll switch that function off (per the last post here). And then hopefully I'll be able to see which downloads need intervention, and run those repairs manually from my Mac.
    However, now sabnzbd isn't able to start up. Are you able to take a look please?
ProSupport for Business
