twc
Jan 12, 2017Aspirant
sabnzbd causes high system load
Hi all, Is it normal that sabnzbd drives the sysload up to 143? (as reported in the top right corner of the web interface) I see three recently finished downloads (with "busy" spinners) in t...
- Jan 23, 2017
I think the NAS runs fine until sabnzbd begins repairing one of the downloads. So, I'll switch that function off (per the last post here). And then hopefully I'll be able to see which downloads need intervention, and run those repairs manually from my Mac.
However, now sabnzbd isn't able to start up. Are you able to take a look please?
twc
Jan 31, 2017Aspirant
Got it, thanks for clarifying.
Mhynlo
Feb 02, 2017Luminary
There are some things that make it easier to go the available apps like knowning what are the available ports, notifying users there are updates, and seems like there ares some testing they run before posting.
Either case; I was able to get most of SABnzbd:
https://github.com/Mhynlo/readynas-sabnzbd/releases/tag/1.2.0-0
I flagged it as pre-release because there are some little things I want to do for hte build process, but the app itself should all be ready and will not be touched when I submit to Netgear.
Please give it a try and let me know what you think.
