oshae
Apr 24, 2016Tutor
Samba daemon using almost 100% CPU
I've only noticed this happening for around 6 months now. I'm running the latest R4 firmware on my Pro 6. Every now and then I will notice file transfers are slow, so I ssh in and fire up top. sm...
oshae
Aug 01, 2016Tutor
Sorry to ressurect this thread. I ended up uninstalling CrashPlan for a while and switched back to the original 1GB DIMM of memory my Pro 6 came with. And to no avail.
I was wondering if perhaps a reinstall of the OS might be worth a try? This is non destructive to my data from what I understand. I assume I will have to reinstall addons etc. however. Although I would probably reinstall and leave it running for a week or so without addons or any changes etc.
Thoughts?
mdgm-ntgr
Aug 01, 2016NETGEAR Employee Retired
Can you send in your logs (see the Sending Logs link in my sig)?
- oshaeAug 01, 2016Tutor
Sent. Thanks mgdm.
- mdgm-ntgrAug 01, 2016NETGEAR Employee Retired
I can see that you have Crashplan installed (and have installed an add-on to update libc6 - which is now needed to use Crashplan on RAIDiator-x86 4.2).
The logs you sent showed smb using about 25%. From a quick look I can see in the samba logs some failed attempts to login using your Windows ID, but that wouldn't suggest samba CPU usage of close to 100% to me.- oshaeAug 02, 2016Tutor
Well, generally when I notice it is using 99% I will stop and start the CIFS service on the device. Sometimes I notice when I'm streaming a video from it (Plex Server hosted on a separate server), the playback will stop to buffer a bunch of times. If I pull up top, sure enough smbd will be pinned.
Would an OS reinstall be worth a try?
