IvanVSA
Aug 07, 2017Aspirant
Samba doesn't work anymore
Hello, pals! Today i'd face the problem with samba on my RN104. After turning the server off and that turned it on everything seemed ok unless i couldn't reach the server via samba. When i tryed to ...
- Aug 07, 2017
Dear Skywalker!
Thank you for help and response. Actually, i tryied to reinstall samba, meditated on logs but finally made OS Reinstall and that helped. So i can not try your advise but anyway thank you!
Skywalker
Aug 07, 2017NETGEAR Expert
Well, I can't tell how it happened, but I can tell you how to fix it. These two commands should take care of it:
# rm /usr/lib/arm-linux-gnueabi/libwbclient.so.0.13 # ldconfig
IvanVSA
Dear Skywalker!
