IvanVSA
Aug 07, 2017Aspirant
Samba doesn't work anymore
Hello, pals! Today i'd face the problem with samba on my RN104. After turning the server off and that turned it on everything seemed ok unless i couldn't reach the server via samba. When i tryed to ...
- Aug 07, 2017
Dear Skywalker!
Thank you for help and response. Actually, i tryied to reinstall samba, meditated on logs but finally made OS Reinstall and that helped. So i can not try your advise but anyway thank you!
IvanVSA
Dear Skywalker!
Skywalker
Aug 07, 2017NETGEAR Expert
You'll probably want to still run that `rm` command anyway. Otherwise, it may revert to a non-working state if you install an app or some other package that includes a new library.
