IvanVSA
Aug 07, 2017Aspirant
Samba doesn't work anymore
Hello, pals! Today i'd face the problem with samba on my RN104. After turning the server off and that turned it on everything seemed ok unless i couldn't reach the server via samba. When i tryed to ...
- Aug 07, 2017
Dear Skywalker!
Thank you for help and response. Actually, i tryied to reinstall samba, meditated on logs but finally made OS Reinstall and that helped. So i can not try your advise but anyway thank you!
IvanVSA
Dear Skywalker!
IvanVSA
UPD!!!
As i wrote before i made OS Reinstall and after it was done at the first reboot Samba starts properly. But after that i made next reboot and the problem accure again.
There is a quote from console:
Spoiler
root@vsa_moscow:~# rm /usr/lib/arm-linux-gnueabi/libwbclient.so.0.13
root@vsa_moscow:~# ldconfig
/sbin/ldconfig.real: libraries libsnapper.so.2.1.0 and libsnapper.so.2.5.0 in directory /usr/lib/arm-linux-gnueabi have same soname but different type.
/sbin/ldconfig.real: /usr/lib/libreadycloud.so.1 is not a symbolic link
