dar3k
Feb 26, 2017Aspirant
Samba doesn't work
Hello I have problem with my samba deamon, after last reboot, my NAS has updated automatically, and now samba doesn't work. I have tried to reinstall samba by hand but [ Spoiler ] I don't have an...
- Mar 01, 2017
You had a broken samba config. So I put the default config back on. It should be fixed now.
Also your attempt to re-install samba somehow installed a dependency of samba with a different version breaking the ability to install samba. After re-installing the dependency with the same version as the samba package I was able to put samba back on.
