dar3k
Feb 26, 2017Aspirant
Samba doesn't work
Hello I have problem with my samba deamon, after last reboot, my NAS has updated automatically, and now samba doesn't work. I have tried to reinstall samba by hand but [ Spoiler ] I don't have an...
- Mar 01, 2017
You had a broken samba config. So I put the default config back on. It should be fixed now.
Also your attempt to re-install samba somehow installed a dependency of samba with a different version breaking the ability to install samba. After re-installing the dependency with the same version as the samba package I was able to put samba back on.
Fiarel
Mar 11, 2017Aspirant
I have exacly this same problem
Could you give more informations how to solve this issue?
Thanks
mdgm-ntgr
Mar 14, 2017NETGEAR Employee Retired
Actually Fiarel your problem is different.
You did an
# apt-get dist-upgrade
Which replaced the samba-common package with one that's incompatible with the samba version in 6.6.1 and removed the samba package.
We don't recommend doing an
or an
# apt-get upgrade
It looks like there could have been a problem with your main SMB config file so I put the default config back on.
The SMB config for your shares was intact and fine.
- FiarelMar 14, 2017Aspirant
Hi,
Thank you for helping, its seems to work now.
Yes i did #apt-get dist-upgrade few times in the past to keep all programs updated. (i will be not doing this as you recomend)
Thank You again
regards
marcin
