dar3k
Feb 26, 2017Aspirant
Samba doesn't work
Hello I have problem with my samba deamon, after last reboot, my NAS has updated automatically, and now samba doesn't work. I have tried to reinstall samba by hand but [ Spoiler ] I don't have an...
- Mar 01, 2017
You had a broken samba config. So I put the default config back on. It should be fixed now.
Also your attempt to re-install samba somehow installed a dependency of samba with a different version breaking the ability to install samba. After re-installing the dependency with the same version as the samba package I was able to put samba back on.
mdgm-ntgr
Mar 14, 2017NETGEAR Employee Retired
Actually Fiarel your problem is different.
You did an
# apt-get dist-upgrade
Which replaced the samba-common package with one that's incompatible with the samba version in 6.6.1 and removed the samba package.
We don't recommend doing an
or an
# apt-get upgrade
It looks like there could have been a problem with your main SMB config file so I put the default config back on.
The SMB config for your shares was intact and fine.
Fiarel
Mar 14, 2017Aspirant
Hi,
Thank you for helping, its seems to work now.
Yes i did #apt-get dist-upgrade few times in the past to keep all programs updated. (i will be not doing this as you recomend)
Thank You again
regards
marcin
