starbase804
Sep 13, 2018Aspirant
Samsung tv + readynas nv+
Hi, does anyone know why my Samsung T32E390SX won't see my readynas. All of my other Samsung UExxxx Tv's see it. It does see my laptop as a media server. All are on the same network, all connect to t...
JohnCM_S
Sep 14, 2018NETGEAR Employee Retired
Hi starbase804,
Have you tried disabling and re-enabling the ReadyDLNA?
What is the firmware of the ReadyNAS NV+?
- starbase804Sep 14, 2018Aspirant
yeah tried that. f/w RAIDiator 4.1.15
just odd that its the one tv. 3 other samsungs see it ok, 2 ps3, 2 ps4's, 1 xbox, 1 firestick and a couple of other devices all see the box ok.
- JohnCM_SSep 14, 2018NETGEAR Employee Retired
Hi starbase804,
What is the version of ReadyDLNA are you running? You may try installing the Sparc add-on update and see if that will help. You can download it here.
- starbase804Sep 14, 2018AspirantThanks, but already running that version.
- TeknoJnkySep 14, 2018Hero
if your other devices can see your nas, then I suggest that it is not the NAS problem, but either a TV problem, or an issue with your network between the affected TV and the nas.
some routers can block the (broadcast) protocols used by dlna, epecially if using WIFI.
Try an ethernet connection if you are using wifi on that tv, or double check if there is a tv firmware update, or if other people on the internet are using that model tv and have problems too.
