starbase804
Sep 13, 2018Aspirant
Samsung tv + readynas nv+
Hi, does anyone know why my Samsung T32E390SX won't see my readynas. All of my other Samsung UExxxx Tv's see it. It does see my laptop as a media server. All are on the same network, all connect to t...
JohnCM_S
Sep 14, 2018NETGEAR Employee Retired
Hi starbase804,
What is the version of ReadyDLNA are you running? You may try installing the Sparc add-on update and see if that will help. You can download it here.
starbase804
Sep 14, 2018Aspirant
Thanks, but already running that version.
- TeknoJnkySep 14, 2018Hero
if your other devices can see your nas, then I suggest that it is not the NAS problem, but either a TV problem, or an issue with your network between the affected TV and the nas.
some routers can block the (broadcast) protocols used by dlna, epecially if using WIFI.
Try an ethernet connection if you are using wifi on that tv, or double check if there is a tv firmware update, or if other people on the internet are using that model tv and have problems too.
- starbase804Sep 14, 2018AspirantThe TV sees the Netgear genie dlna running on my laptop. Is there any difference between the ready Nas and the genie app?
No idea, but the NV+ is a very old device (I have one too), so I would not expect to have the latest and greatest dlna support.
But if the NV+ works with your other tvs, then obviously it is working, so while I suppose there could be something the tv doesn't like with the nv+, I would expect the problem to be related to the TV itself, or the network connection, as previously mention.
As a fellow home media streamer, I would suggest you look into PLEX and consider upgrading to a newer model readynas thats capable of running the current version of plex server.
You can still keep the NV+ around for backup and/or extra storage, but its unfortunately it is not very well suited for todays media streaming needs (In my opinion as a fellow owner of one).
