chelsel
Aug 12, 2008Aspirant
Seagate ST31500341AS 1.5TB
Any idea when this will be supported :-) Cliff
bollar
Oct 08, 2008Aspirant
jmirabil wrote: Anyone yet successfully loaded four ST31500341AS 1.5TB drives into a Readynas NV+ and obtained a fully operational ~4.5TB xraid drive?
Does not look like it yet... Any capacity "screenshots"? I'm curious to see what the max capacity and (typical/max) drive temps are under xraid! Hopefully these drives are faster than the green power drives which seemingly cannot suspend-but it's no big deal really to me.
Currently weighing whether to go with 1TB GP drives or try these new 1.5TB drives...
I have.
Disk space:
2423 GB (58%) of 4163 GB used
Additional 5 GB reserved for snapshots
RAID Configuration
Configuration: X-RAID (Expandable RAID), 4 disks
Status: Redundant
RAID Disks:
Ch 1 : Seagate ST31500341AS [1397 GB] 1393 GB allocated
Ch 2 : Seagate ST31500341AS [1397 GB] 1393 GB allocated
Ch 3 : Seagate ST31500341AS [1397 GB] 1393 GB allocated
Ch 4 : Seagate ST31500341AS [1397 GB] 1393 GB allocated
I was having a problem about a day after the installation where I couldn't delete a file. I decided to reboot with a file/quote check and that failed with a kernel panic. I restarted and it proceeded to do a resync and has been fine since. I did notice a sector reallocation on one of the drives, which I presume was the cause of the problem.
