chelsel
Aug 12, 2008Aspirant
Seagate ST31500341AS 1.5TB
Any idea when this will be supported :-) Cliff
Balders1
Oct 09, 2008Aspirant
What you've done is broken the array. You've expanded to 4 drives by placing the additional 2 drives in the two empty slots. You should have replaced the 750GB drives 1 at a time.
You cannot move from 4 drives to 3.
You have two options:
1) leave the 750GB in and do without the additional space the 1.5TB drives give you.
2) buy an extra 1.5TB to replace the 750GB you've taken out.
Balders
Balders
Blues wrote: I purchased a new ReadyNAS NV+ a couple of weeks ago with 2 750GB drives. I kept it in X-RAID and loaded ~100GB of data onto it.
Then I purchased 3 of the Seagate 1.5TB drives. I added two in the two empty slots and it went for hours to initialize them. I then took out one of the 750GB drives and replaced it with my third 1.5TB. All was according to what I expected. The Volume Settings page showed 1 698 GB Seagate with 694 GB allocated and 3 1397GB Seagates with 694 GB allocated. All my data was there.
I then removed the 1 smaller drive (in slot 1) and after rebooting several times it's still not understanding that it's supposed to expand. It shows:
Disk space: 101 GB (4%) of 2076 GB used
Additional 5 GB reserved for snapshots
Configuration: X-RAID (Expandable RAID), 4 disks
Status: Not redundant. A disk failure will render this volume dead.
RAID Disks:
Ch. 1: UNKNOWN [698 GB]
Ch. 2: Seagate ST31500341AS [1397 GB] 694 GB allocated
Ch. 3: Seagate ST31500341AS [1397 GB] 694 GB allocated
Ch. 4: Seagate ST31500341AS [1397 GB] 694 GB allocated
Does anyone know how to make it forget about the fourth drive and give me 3 1.5 X-RAID drives for ~2700 GB?
Thank you.
