chelsel
Aug 12, 2008Aspirant
Seagate ST31500341AS 1.5TB
Any idea when this will be supported :-) Cliff
zxgates
Oct 09, 2008Aspirant
FWIW, my configuration matches Bollar's almost exactly.
I also had the sector reallocation on two drives, but everything has worked perfectly since the 4.14 update. Following is the Health screen on my NV (not an NV+). (note, that room stays unusually hot as the door is closed to keep out animals. I need to fix that to get all the temps down a bit)
Disk 1 Seagate ST31500341AS 1397 GB , 46 C / 114 F , Write-cache ON OK
Disk 2 Seagate ST31500341AS 1397 GB , 53 C / 127 F , Write-cache ON OK
Disk 3 Seagate ST31500341AS 1397 GB , 53 C / 127 F , Write-cache ON OK
Disk 4 Seagate ST31500341AS 1397 GB , 46 C / 114 F , Write-cache ON OK
Fan 1 1875 RPM OK
Temp 1 39.0 C / 102 F [Normal 0-60 C / 32-140 F] OK
UPS 1 Not present OK
Fan 1 1875 RPM OK
