chelsel
Aug 12, 2008Aspirant
Seagate ST31500341AS 1.5TB
Any idea when this will be supported :-) Cliff
bollar
Oct 09, 2008Aspirant
zxgates wrote: (note, that room stays unusually hot as the door is closed to keep out animals. I need to fix that to get all the temps down a bit)
It's not just you. Here is my configuration in a room that has an ambient temperature of 82F. 82 seems like a reasonable temperature to keep a room, so I'm not going to make any special measures to lower the temp.
Device Description Status
Disk 1 Seagate ST31500341AS 1397 GB , 46 C / 114 F , Write-cache ON OK
Disk 2 Seagate ST31500341AS 1397 GB , 52 C / 125 F , Write-cache ON OK
Disk 3 Seagate ST31500341AS 1397 GB , 53 C / 127 F , Write-cache ON OK
Disk 4 Seagate ST31500341AS 1397 GB , 46 C / 114 F , Write-cache ON OK
Fan 1 2142 RPM OK
Temp 1 39.0 C / 102 F [Normal 0-60 C / 32-140 F] OK
UPS 1 APC Back-UPS RS 1500, Battery charge: 100%, 54 minutes OK
