chelsel
Aug 12, 2008Aspirant
Seagate ST31500341AS 1.5TB
Any idea when this will be supported :-) Cliff
ryanmacl
Nov 02, 2008Aspirant
Can someone help me out here? I purchased 4 of these the day they went on the HCL. I had 2 come with a bunch of bad sectors, sent them back, now I'm rocking with 4 pristine 1.5t's. However, I've had a problem with the ReadyNAS (NV) crashing intermittently ever since I upgraded to these drives. It becomes completely unresponsive, even to the front button, and I am forced to unplug it to get it working again. At that point, it does a FS check, resyncs after several hours, and then works fine again. It was happening with the old drives, and is still happening with the new ones. Everything I've read so far states the drives lock up for 30 seconds if streaming, but this is crashing the unit altogether. Is this a related problem?
I've downloaded all logs (just let me know where to send them if you need them) and when the current sync is done I've re-downloaded and will reinstall the firmware. Is there anything I can do or will I just have to live with intermittent crashes until these are back on the HCL?
