chelsel
Aug 12, 2008Aspirant
Seagate ST31500341AS 1.5TB
Any idea when this will be supported :-) Cliff
phrozen
Nov 20, 2008Aspirant
racicot wrote: Looks like some sort of activity from Seagate on this... any word if there will be an ability to update the firmware on an existing RAID setup with these drives installed? Is there hope that a new version of RAIDiator would be able to fix this?
http://forums.seagate.com/stx/board/mes ... 3116#M3116
You'll probably have to pull out the drives one by one and install them in a desktop or hook them up to an eSATA port to flash them. I had to do that with one of my 750 GB drives.
I just submitted my request for the updated firmware. Can someone with 4x 1.5 TB drives confirm that the new firmware fixes the problem on the ReadyNAS? I will test the drives I have, but they are connected to PCs.
