chelsel
Aug 12, 2008Aspirant
Seagate ST31500341AS 1.5TB
Any idea when this will be supported :-) Cliff
Marde
Dec 03, 2008Aspirant
Here you go guys. The files are at Wikisend, a free service where the files should be available for the next 7 days only. After you download, check to see that your zip file is the same size as what I have here on my win-xp box : select file -> right click -> properties
CC1H zip file size 2,911,767 bytes : size on disk 2,912,256 bytes
SD1A zip file size 2,904,563 bytes : size on disk 2,908,160 bytes
wikisend.com: ST31500341AS_CC1H.zip
stashbox.org: ST31500341AS_CC1H.zip
wikisend.com: ST31500341AS_SD1A.zip
stashbox.org: ST31500341AS_SD1A.zip
