chelsel
Aug 12, 2008Aspirant
Seagate ST31500341AS 1.5TB
Any idea when this will be supported :-) Cliff
Theresias
Dec 04, 2008Tutor
Just spoke to a Seagate representative and my SD17 is also being updated to SD1A. Since the drive is currently in use I do expect some results later today and then may probably be able to tell you if that helped or not. By the way, there are only these 2 firmware versions available, so the links Marde provided (thanks for that) should do it for everybody.
Going to back up the whole thing now... :?
