chelsel
Aug 12, 2008Aspirant
Seagate ST31500341AS 1.5TB
Any idea when this will be supported :-) Cliff
chirpa
Dec 05, 2008Luminary
I wasn't able to fully test mine, one of three disks I got was DOA, have to RMA it (and get a refurb replacement it seems).
ijhammo wrote: Can anyone confirm that the issue exists on CC1G firmware?
Yes, I did modify the post. Try and save your images as JPG, not BMP. Then upload it on StashBox and it gives you a Forum Image code link you can paste here.
Marde wrote: Chirpa, A few posts back -either you or some mod changed my post pictures (img's) from wikisend to stashbox, which allows the picture to display in the thread. Thank you for doing that. I might go have a look at stashbox services later.
