chelsel
Aug 12, 2008Aspirant
Seagate ST31500341AS 1.5TB
Any idea when this will be supported :-) Cliff
bdl99
Dec 20, 2008Aspirant
nvladik wrote: It will correct itself when all 4 drives are changed, right now it's taking it as the smallest drive.
Thanks for the quick response, I would have been more comfortable if it had still said 372 GB (I'm replacing 400GB drives), but it changed from 372Gb to 465Gb
Device Description Status
Disk 1 Seagate ST31500341AS 465 GB , 41 C / 105 F , Write-cache ON OK
Disk 2 Seagate ST3400832AS 372 GB , 42 C / 107 F , Write-cache ON OK
Disk 3 Seagate ST3400832AS 372 GB , 41 C / 105 F , Write-cache ON OK
Disk 4 Seagate ST3400633AS 372 GB , 43 C / 109 F , Write-cache ON OK
The first disk is now fully initialized and RAID sync is finished so the volume is now fully redundant
My experience seems to differ from others here
Marde wrote: Sharing information about disk expansion on a NV+.
Current NV+ is X-RAID using four 750GB disks.
Started upgrading system to four 1.5TB disks.
First disk replaced yesterday. It took 8+ hours to finish the first disk, 4 hours of Init and 4 hours of RAID Sync.
Frontview -> Volumes -> Raid Settings, shows the first 1.5TB disk as [1397 GB].
I'm still reluctant to put the next disk in without asking.
