chelsel
Aug 12, 2008Aspirant
Seagate ST31500341AS 1.5TB
Any idea when this will be supported :-) Cliff
bonez
Dec 28, 2008Aspirant
mattkime wrote: also, could the previous set of disks be used to rebuild the raid set if the new drives failed?
The answer I got when I asked the same question was 'yes'. If you set them aside you can always put them back in later...guessing that means no changes to the NAS software, assumes working hardware later on, etc.
