chelsel
Aug 12, 2008Aspirant
Seagate ST31500341AS 1.5TB
Any idea when this will be supported :-) Cliff
phrozen
Dec 29, 2008Aspirant
bonez wrote:
mattkime wrote: also, could the previous set of disks be used to rebuild the raid set if the new drives failed?
The answer I got when I asked the same question was 'yes'. If you set them aside you can always put them back in later...guessing that means no changes to the NAS software, assumes working hardware later on, etc.
I think the answer is "no", if you are talking about preserving the data on the RAID. I think once the expansion happens, there is no way to go back to a smaller set of disks while still preserving the data. You can go back to the previous disks, but all the data will have to be erased...
