chelsel
Aug 12, 2008Aspirant
Seagate ST31500341AS 1.5TB
Any idea when this will be supported :-) Cliff
mattkime
Dec 29, 2008Aspirant
>>Almost positive you can't de-expand.
oh, certainly.
but if you're switching between two complete sets of four drives, then the expansion doesn't occur until after all the drives have been replaced. four old drives, pre expansion and four new drives, post expansion. in this situation you could swap between drive sets, correct?
unless the data on each drive is altered as one drive is removed from the set and another drive is added. oh, that would assume the data stays exactly the same...
hm, yeah, seems less likely than i initially thought it would be.
oh, certainly.
