chelsel
Aug 12, 2008Aspirant
Seagate ST31500341AS 1.5TB
Any idea when this will be supported :-) Cliff
bonez
Dec 29, 2008Aspirant
fearless_fool wrote: My conclusion: Given the poor reliability record of the Seagate 1.5TB drives, I'm not ready to risk an irreversible expansion using them. I'll be ordering four of the Samsung HD103UJ 1TB drives instead.
That was where I was at until I somehow found a way to move data on to other drives on my network...I didn't have space, but was able to make room. This also included just deleting some of the raw DVD backups I had (I actually have the DVDs..so it just means having to rip them again in case of problems). If you don't have the space, then I think you're taking a very reasonable approach...just make sure you really don't have the space :)
Good luck!
