chelsel
Aug 12, 2008Aspirant
Seagate ST31500341AS 1.5TB
Any idea when this will be supported :-) Cliff
starbuck_
Jan 06, 2009Aspirant
I just spoke with Seagate support regarding the firmware update.
First I should test if this problem occur on my 2 drives. If so I should flash the new Firmware SD1A.
How do I handle the process correctly?
1) Insert drive 1 and let the readynas make the raid expansion
2) when completed insert the 2nd Drive and also let expand it.
3) Testing if Firmware is needed--->If so Flash new Firmware via PC.
4)Re-Insert Drive into Readynas?
Now my question is? Is the data still intact or will I have to do something special?
Reformat after FW upgrade and start expansion once again?
Any advice?
Any advice?
