chelsel
Aug 12, 2008Aspirant
Seagate ST31500341AS 1.5TB
Any idea when this will be supported :-) Cliff
iProb8
Jan 06, 2009Guide
I just finished the firmware upgrade all my three drives (from CC1G to CC1H). All seemed to go just fine. The upgrade process itself took less than a minute each; disconnecting and connecting the drives from the PC and then rebooting the PC in between each upgrade took about twice as long. ;-)
When I get home this evening, I'll pull the drive that is failing and replace it with one of the new ones. Must I shut down the ReadyNAS before I do the swap? Or, can I hot swap them? I believe everything I've read indicates a hot swap is okay, but I want to be sure that a hot swap is 100% safe.
