chelsel
Aug 12, 2008Aspirant
Seagate ST31500341AS 1.5TB
Any idea when this will be supported :-) Cliff
phrozen
Jan 06, 2009Aspirant
phrozen wrote:
You have to follow the emergency unlock procedure using a thumb tack. I keep one next to the ReadyNAS 24/7.
Also, it's not even the "first" emergency unlock procedure where you stick the thumb tack into the button hole. That doesn't work either. I always have to put it in the third vent hole and pull it down. They describe it somewhere on the wiki or FAQ....
