chelsel
Aug 12, 2008Aspirant
Seagate ST31500341AS 1.5TB
Any idea when this will be supported :-) Cliff
phrozen
Jan 06, 2009Aspirant
egoldy wrote: You pulling my leg here?
What WIKI or FAQ are you referring to?
Stick a thumbtack in the hole of the button (of the third drive?) and then what?
How hard do you have to push ?
For one of the other Netgear routers, I did see something about sticking a paperclip in a similar "hole" and tried that earlier (lightly) and nothing... I didn't push HARD though..
There's not a video on youtube or something to point to is there?
I just don't want to F' this **** up !
Thanks..
You don't push. It is insert and then pull down. I think I use the the hole slightly to the left of the "B" arrows. It is really easy once you get the hang of it.
viewtopic.php?p=30550#p30550
