chelsel
Aug 12, 2008Aspirant
Seagate ST31500341AS 1.5TB
Any idea when this will be supported :-) Cliff
derrick2
Jan 08, 2009Aspirant
HI All,
i just got 4 1.5TB CC1G drives. . drives are not formatting properly. . RAIDER doesn't seem to pick up the drive after the 4 lights come on at 30s while doing a system reset. then after a while, it just chas C: formatting, and only formats to 2.1TB!
Have emailed and called seagate in the last 2 days, and still have not had an email with the firmware update. . just wondering how long you guys have had to wait for the email with firmware update? Also has anyone else had this problem of not being able to connect to the Readynas when trying to do a system reset to format the drives in XRAID?
thanks!
Derrick
Readynas NV+
4x Seagate 1.5TB CC1G
Macbook Pro 15" unibody 2.53Ghz
Dell 24"
thanks!
Derrick
Readynas NV+
Dell 24"
