chelsel
Aug 12, 2008Aspirant
Seagate ST31500341AS 1.5TB
Any idea when this will be supported :-) Cliff
iProb8
Jan 09, 2009Guide
derrick wrote: HI All,
i just got 4 1.5TB CC1G drives. . drives are not formatting properly. . RAIDER doesn't seem to pick up the drive after the 4 lights come on at 30s while doing a system reset. then after a while, it just chas C: formatting, and only formats to 2.1TB!
Have emailed and called seagate in the last 2 days, and still have not had an email with the firmware update. . just wondering how long you guys have had to wait for the email with firmware update? Also has anyone else had this problem of not being able to connect to the Readynas when trying to do a system reset to format the drives in XRAID?
thanks!
Derrick
I called Seagate on this past Tuesday (1/6). I waited on hold for about 20 minutes before I was able to talk to a representative. I gave him the part numbers, serial numbers, and firmwares off the labels on the drives. About 30-45 minutes later, I received an e-mail with a link and instructions as to how to obtain the firmware upgrade. Please note that to upgrade the firmware, you will need to connect the drives directly to a SATA port on your computer; you cannot upgrade the firmware when the drive is in the ReadyNAS or other type of external enclosure. Good luck!
