chelsel
Aug 12, 2008Aspirant
Seagate ST31500341AS 1.5TB
Any idea when this will be supported :-) Cliff
phrozen
Jan 09, 2009Aspirant
darwin wrote: I just received 2 of these drives from Newegg (2 more coming from Amazon... yes, I'm anal when it comes to hard drives). These have firmware revision SD19 printed on the labels.. I see that most of the links to the firmware updates aren't around anymore. Has anyone heard of this revision? Any issues with it or need to update it? I see that it seems to be at least a few revs higher than the C***.
I haven't put them in a computer to verify
Thanks
SD1A should be the latest for you. Those are different P/Ns than the drives with CC1H...
