chelsel
Aug 12, 2008Aspirant
Seagate ST31500341AS 1.5TB
Any idea when this will be supported :-) Cliff
Jellen
Jan 13, 2009Aspirant
I just transfer with Drag and drop in windows over CIFS. Tested both on a wired xp and vista system (same results)
I use DU meter to measure the speed. Where I used to get a fluctuation of 40MiB/sec using the mentioned duo system.
It really 'maxes out' and stays constant at 20MiB/sec when writing to the NV+ with the two CC1H. (Readynas optimized for speed except jumbo frames, same settings as the Duo..)
Tried with different file sizes and types but all show up as a 'straight line' maxed at 20MiB/sec on the Du meter.
Kind regards
Kind regards
