chelsel
Aug 12, 2008Aspirant
Seagate ST31500341AS 1.5TB
Any idea when this will be supported :-) Cliff
phrozen
Jan 17, 2009Aspirant
I have 4x 1.5 TB drives in my Readynas NV. I don't have jumbo frames enabled. Copying to / from a Vista desktop I see 18 MB/s write speed and 36 MB/s read speed. The write isn't that surprising to me because it was about the same with the 4x 750 GB drives. The read speed is much higher than I was expecting. I don't remember seeing that kind of speed without jumbo frames.
Jellen, did you go from a 2x drive configuration to a 3 or more drive configuration? You may have seen better write speeds because before you were just mirroring data. With 3 or more drives, there will have to be a parity calculation, which could explain the slowdown. The readynas might be faster with mirroring only...
