chelsel
Aug 12, 2008Aspirant
Seagate ST31500341AS 1.5TB
Any idea when this will be supported :-) Cliff
phrozen
Jan 18, 2009Aspirant
Jellen wrote:
phrozen wrote: I have 4x 1.5 TB drives in my Readynas NV. I don't have jumbo frames enabled. Copying to / from a Vista desktop I see 18 MB/s write speed and 36 MB/s read speed. The write isn't that surprising to me because it was about the same with the 4x 750 GB drives. The read speed is much higher than I was expecting. I don't remember seeing that kind of speed without jumbo frames.
Jellen, did you go from a 2x drive configuration to a 3 or more drive configuration? You may have seen better write speeds because before you were just mirroring data. With 3 or more drives, there will have to be a parity calculation, which could explain the slowdown. The readynas might be faster with mirroring only...
It is mirroring only, my previes Readynas was a Duo with two 500GB drives (Seagate) X-raid
Fresh new NV+ with two 1.5TB (also X-Raid, or mirroring) and I see only half the throughput speed of the duo with its 500GB drives..
Read speed is around 27MiB/Sec on those drives (maybe faster in a 4x system)
Kind regards
Jellen
I think the duo might be faster than the NV? Have you tried the 500 GB drives in the NV or the 1.5 TB drives in the Duo?
