chelsel
Aug 12, 2008Aspirant
Seagate ST31500341AS 1.5TB
Any idea when this will be supported :-) Cliff
Jellen
Jan 20, 2009Aspirant
darwin wrote:
Jellen wrote: But as I said in previes posts, I got a write result of 40MiB/sec on a two drive 500GiB Readynas Duo setup.
Identical setup, identical network, idenctial optimized network settings (except jumboframes)
So I hope to see some other speed results with these drives in in NV+ config, maybe then I can figure out how to optimize performance or buy other drives.
Kind regards
Jellen
You should be able to get 40-45MB/sec out of your NV+. The Infrant benchmarks were very low on the device, there was probably a bottleneck other than the readynas they tested. I was getting the speed they advertised in their benchmarks initially... As soon as I went from a linksys 8 port prosumer gig-e switch to a nice HP gig=e 24port switch I noticed a huge difference, upgraded my workstation and noticed more. my NV currently gets 40-45MB/sec
Indeed, also the speeds I expect, not an average of 45 MB/Sec but at least something more than a Constant! max of 23MB/sec.
What is your config of your Readynas NV+ ?
