chelsel
Aug 12, 2008Aspirant
Seagate ST31500341AS 1.5TB
Any idea when this will be supported :-) Cliff
Webaccess
Jan 21, 2009Aspirant
bdl99 wrote:
bdl99 wrote: So after a bit of a rollercoaster ride I now have my ReadyNAS with 4 1.5Tb Seagate ST31500341AS drives installed (3 x SD17 firmware upgraded to SD1A and 1 x CC1H )
The good news I've seen no signs of stuttering or hanging since expansion. I've just watched a movie while copying other files with no issues.
The only issue to date had been one Reallocated Sector on disk four less than 24 hours after expansion.
Four days later and I had another reallocated sector (making 2) and then yesterday a third. For those that RMA'd disks, how many reallocated sectors did it take before you RMA'd the disk? For those who purchased through Amazon did you RMA to Amazon or directly with Seagate?
The first three disks are holding steady at 0 so hopefully they came from a good batch.
I RMA every disk with more than 0 reallocated sectors.
I just received a new disk which is replacing a disk with 1 reallocated sector
It should not happen and (from my opinion) the reallocated sectors are only there to prevent data lose for a short time and to give you the time to replace the disk.
