chelsel
Aug 12, 2008Aspirant
Seagate ST31500341AS 1.5TB
Any idea when this will be supported :-) Cliff
BotanyBay
Jan 28, 2009Tutor
Just got my Pro and loaded a single 1.5TB Seagate into it (came with CC1H firmware), decided to go with it as shop has a no questions asked 30 day return policy and I needed a drive to test out the box so seems like an excellent opportunity to work with the 1.5TB drives and work through the setup for the Pro.
The drive was built in Thailand with a part number of 9JU138-336 and came loaded with the CC1H firmware, date code is 09294.
After about 12 hours of running (loading fully backed up non-sensitive data) no errors yet. Keeping a close eye on the smart tab for the drive.
An off topic question, I have the box directly connected to the PC and I am getting about 20mb/sec write rates to a single disk. I don't know if I am readynas Pro limited or PC limited (the data is coming off two USB attached drives). Just wondering if anyone has some performance numbers for a single drive setup.
