alokeprasad
Nov 09, 2018Mentor
Secure connection to Readynas Duo v1
It has been a while since I did a local access to my Duo ( https://192.168.1.100/admin/ )
I am getting certificate errors now in Chrome (ERR_SSL_VERSION_OR_CIPHER_MISMATCH); Firefox v63.0.1 (SSL_ER...
Nov 09, 2018Guru - Experienced User
alokeprasad wrote:
How do I fix this?
Use http I guess (http://192.168.1.100/admin). There might be some other security settings changes that might work (with firefox anyway).
You shouldn't be allowing over-the-internet access to your NAS anyway, since it's been EOL for a long time, and isn't getting security updates.
alokeprasad
Nov 12, 2018Mentor
Latest versions of browsers are enforcing TLS even if I type http:\\ ...
They are not finding a way for secure access to the device.
I an not accessing the device over WAN. This is over my internal LAN (my side of the router.
The 192.186.x.x are locally available addresses anyway...
- StephenBNov 12, 2018Guru - Experienced User
They won't if you disable https on the Duo (which is an option under services). Though the trick now is to get it to connect once, so you can do that.
You could try using IE perhaps in compatibility mode, or temporarily installing an older version of FireFox or Chrome.
FWIW, I am not seeing this issue on my own Duo and NV+, and both have https enabled. FireFox and Chrome say they are up to date, though Chrome is version 70.0.3538.102, not version 71.
- alokeprasadNov 17, 2018Mentor
I was able to connect to Duo v1 using Safari on an iPad. The browser there allowed me to bypass the warnings and connect anyway to the Duo.
How/where do I disable encrypted TLS/https access to the device?
I expect that will be good enough security as this is inside my LAN and with a local non-routable IP address 192.168.1.100
PS: Will it help to re-start the device?
Aloke
- StephenBNov 19, 2018Guru - Experienced User
services->standard file protocols has a checkbox for https.
It might.
