davidr1
Jul 14, 2017Luminary
sensible-editor: select-editor: not found
I have just installed my new 212 unit. After exiting crontab -e I get this: "/usr/bin/sensible-editor: 22: /usr/bin/sensible-editor: select-editor: not found" The contents of crontab save...
Hopchen
Jul 15, 2017Prodigy
Hey,
The /usr/bin/sensible-editor script specifies what editor and visual environment to launch per default. It uses the program "select-editor", but that program is not installed on the NAS it seems. Probably because there is no need to since "vi" is the only editor on the NAS - out of the box.
The error does not matter. It will only occur when editing a program but not specifying the editor to use (such as crontab -e). If you for example did vi /etc/crontab then the error should not occur as you specify the editor to use.
You can always install the select-editor program to "fix" the error you see, but there is no need to.
- davidr1Jul 16, 2017Luminary
Thanks for your reply Hopchen
This didn't this happen on my other units. Annoying. I'll try some settings for the default editor.
Thanks
