wdolson's avatar
wdolson
Apprentice
Nov 17, 2023
SSH mdadm no found
I wrote last week about my RN628X converting from a Raid 5 to Raid 6 when I put in a 7th drive.  Sandshark had information on how to convert it back using mdadm.
I tried it and got a message that mdadm wasn't found.  I used
apt-get install mdadm brtfs-progs
to try and install it, but for the message that the lock file could not be open with permission denied and asked it I was root.
From what I read setting up the connection with puTTy should have logged me in as root (I am logged in with the admin account).  What am I doing wrong?
    No need to install either mdadm or btrfs, and best not to try.
    Likely you couldn't find it because you didn't log in as root.
    When you use ssh, you need to log in as root, using the NAS admin password.
  • schumaku's avatar
    schumaku
    Hard to say, certainly no need to install anything.
    The (default) path is
    root@RN628X:~# set | grep PATH
    PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
    root@RN628X:~# find / -name mdadm
    /etc/mdadm
    /etc/default/mdadm
    /etc/logcheck/violations.d/mdadm
    /etc/logcheck/ignore.d.server/mdadm
    /run/mdadm
    /sbin/mdadm
    /usr/share/lintian/overrides/mdadm
    /usr/share/mdadm
    /var/lib/mdadm
    root@RN628X:~# which mdadm
    /sbin/mdadm
  • StephenB's avatar
    • wdolson's avatar
      wdolson
      Apprentice
      You're right.  I was logged in as admin, not root.  I closed the SSH session and reopened using root and it worked.
      Thanks
ProSupport for Business
