wdolson
Nov 17, 2023Apprentice
SSH mdadm no found
I wrote last week about my RN628X converting from a Raid 5 to Raid 6 when I put in a 7th drive. Sandshark had information on how to convert it back using mdadm. I tried it and got a message that md...
- Nov 17, 2023
I tried it and got a message that mdadm wasn't found. I used
apt-get install mdadm brtfs-progs
No need to install either mdadm or btrfs, and best not to try.
Likely you couldn't find it because you didn't log in as root.
When you use ssh, you need to log in as root, using the NAS admin password.
schumaku
Nov 17, 2023Guru - Experienced User
Hard to say, certainly no need to install anything.
The (default) path is
root@RN628X:~# set | grep PATH
PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
root@RN628X:~# find / -name mdadm
/etc/mdadm
/etc/default/mdadm
/etc/logcheck/violations.d/mdadm
/etc/logcheck/ignore.d.server/mdadm
/run/mdadm
/sbin/mdadm
/usr/share/lintian/overrides/mdadm
/usr/share/mdadm
/var/lib/mdadm
root@RN628X:~# which mdadm
/sbin/mdadm
