Naveenkumar001
Feb 19, 2025Aspirant
Service management offline
hi ..Please help me on this am getting Service management is offine .unable to access my admin page .but i able to download logs. Am using Readynas 3312. I have data in this .I need that data too...
- Feb 21, 2025
Naveenkumar001 wrote:>>> Is SSH enabled on the NAS?
Yes
I suggest accessing the NAS with ssh, and then check that your data is there (ls -als /data).
The logs show that the volume is mounted, but I am seeing unexplained BTRFS timeouts:
Feb 20 10:53:40 DHTL-TP1-NAS kernel: INFO: task btrfs-transacti:4250 blocked for more than 200 seconds. Feb 20 10:53:40 DHTL-TP1-NAS kernel: Tainted: P O 4.1.30.x86_64.1 #1 Feb 20 10:53:40 DHTL-TP1-NAS kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message. Feb 20 10:53:40 DHTL-TP1-NAS kernel: btrfs-transacti D ffff88021321bd68 0 4250 2 0x00000000 Feb 20 10:53:40 DHTL-TP1-NAS kernel: ffff88021321bd68 ffffffff88e2c4a0 ffff880265f08fc0 ffff88026fc147c0 Feb 20 10:53:40 DHTL-TP1-NAS kernel: ffffffff88e2c8d8 ffff88026fc147c0 ffff88021321c000 ffff880265d8f1f0 Feb 20 10:53:40 DHTL-TP1-NAS kernel: ffff880265d8f1f0 0000000000000000 ffff88026644b370 ffff88021321bd88 Feb 20 10:53:40 DHTL-TP1-NAS kernel: Call Trace: Feb 20 10:53:40 DHTL-TP1-NAS kernel: [<ffffffff88a4f1e2>] schedule+0x32/0x80 Feb 20 10:53:40 DHTL-TP1-NAS kernel: [<ffffffff882e62df>] wait_current_trans.isra.34+0x9f/0x100 Feb 20 10:53:40 DHTL-TP1-NAS kernel: [<ffffffff8809c8c0>] ? add_wait_queue+0x60/0x60 Feb 20 10:53:40 DHTL-TP1-NAS kernel: [<ffffffff882e7e58>] start_transaction+0x2c8/0x550 Feb 20 10:53:40 DHTL-TP1-NAS kernel: [<ffffffff882e8142>] btrfs_attach_transaction+0x12/0x20 Feb 20 10:53:40 DHTL-TP1-NAS kernel: [<ffffffff882e4d0b>] transaction_kthread+0x7b/0x240 Feb 20 10:53:40 DHTL-TP1-NAS kernel: [<ffffffff882e4c90>] ? open_ctree+0x24b0/0x24b0 Feb 20 10:53:40 DHTL-TP1-NAS kernel: [<ffffffff88082bb4>] kthread+0xc4/0xe0 Feb 20 10:53:40 DHTL-TP1-NAS kernel: [<ffffffff88082af0>] ? kthread_freezable_should_stop+0x60/0x60 Feb 20 10:53:40 DHTL-TP1-NAS kernel: [<ffffffff88a523d2>] ret_from_fork+0x42/0x70 Feb 20 10:53:40 DHTL-TP1-NAS kernel: [<ffffffff88082af0>] ? kthread_freezable_should_stop+0x60/0x60On SMB access, I am seeing a lot of errors that look like this:
[2025/02/20 16:12:33.035542, 2] ../source3/auth/auth.c:315(auth_check_ntlm_password) check_ntlm_password: Authentication for user [IMW] -> [IMW] FAILED with error NT_STATUS_NO_SUCH_USERIs IMW an account that should exist on the NAS?
You are running very old firmware (6.6.0 - released in 2016). You appeared to make an attempt to update to 6.10.10 on 19 Feb
Feb 19 2025 17:04:49 INFO:UPLOAD_IMAGE: _filename_=ReadyNASOS-6.10.10-x86_64.zip _filesize_=90385981 Feb 19 2025 17:04:50 INFO:GET_REMOTE_INFO: name=ReadyNASOS version=6.10.10 size=90783744 md5=b2f2ee74b9bbf269d449490b24b370fe arch=x86_64 Feb 19 2025 17:04:50 INFO: arch=x86_64 personality= sysinfo->personality=1 Feb 19 2025 17:04:50 INFO:UPLOAD_IMAGE: Checking file for md5... Feb 19 2025 17:04:50 INFO:CHECK_MD5_SUM: local=b2f2ee74b9bbf269d449490b24b370fe remote=b2f2ee74b9bbf269d449490b24b370fe Feb 19 2025 17:04:50 INFO:CHECK_MD5_SUM: MD5 OK! Create link in /etc/.flash_update -> .flash_update_file Feb 19 2025 17:04:50 INFO:UPLOAD_IMAGE: Write info to .flash_update_info... Feb 19 2025 17:04:50 INFO:UPLOAD_IMAGE: SUCCESSAfter that you appear to have downgraded back to 6.6.0
Feb 19 2025 17:29:10 INFO:UPLOAD_IMAGE: _filename_=ReadyNASOS-6.6.0-x86_64.img _filesize_=63207424 Feb 19 2025 17:29:10 INFO:GET_REMOTE_INFO: name=ReadyNASOS version=6.6.0 size=63207424 md5=aec396425a099a22e0fc4f43bbe6ac69 arch=x86_64 Feb 19 2025 17:29:10 INFO: arch=x86_64 personality= sysinfo->personality=1 Feb 19 2025 17:29:10 INFO:UPLOAD_IMAGE: Checking file for md5... Feb 19 2025 17:29:10 INFO:CHECK_MD5_SUM: local=aec396425a099a22e0fc4f43bbe6ac69 remote=aec396425a099a22e0fc4f43bbe6ac69 Feb 19 2025 17:29:10 INFO:CHECK_MD5_SUM: MD5 OK! Create link in /etc/.flash_update -> .flash_update_file Feb 19 2025 17:29:10 INFO:UPLOAD_IMAGE: Write info to .flash_update_info... Feb 19 2025 17:29:10 INFO:UPLOAD_IMAGE: SUCCESSCan you give more details on what you were doing here?
Feb 19, 2025Guru - Experienced User
Did you try running the diagnostic from RAIDar?
Are you seeing any clues in the log zip?
- Naveenkumar001Feb 19, 2025Aspirant
On diagnostic. it's said some sector count in HDD 5. So we removed that 5 no HDD and restarted again ..No Improvement.
Did nt find any clues in Logs..Can u say which log file majorly i shud check for finding clues.
- 2025-02-20 10:30:36: md/raid:md127: raid level 6 active with 11 out of 12 devices, algorithm 2
Am getting this in Diagonastic screen of raidar.
- StephenBFeb 20, 2025Guru - Experienced User
What happens when you try to access the data
- Naveenkumar001Feb 20, 2025AspirantI can able to reach the data of folder...but the final folder loading many hours..and showing empty...Atleast if able to copy paste data....it more good....
- Jun 10, 2022Retired_Member
