Naveenkumar001
Feb 19, 2025Aspirant
Service management offline
hi ..Please help me on this am getting Service management is offine .unable to access my admin page .but i able to download logs. Am using Readynas 3312. I have data in this .I need that data too...
- Feb 21, 2025
Naveenkumar001 wrote:>>> Is SSH enabled on the NAS?
Yes
I suggest accessing the NAS with ssh, and then check that your data is there (ls -als /data).
The logs show that the volume is mounted, but I am seeing unexplained BTRFS timeouts:
Feb 20 10:53:40 DHTL-TP1-NAS kernel: INFO: task btrfs-transacti:4250 blocked for more than 200 seconds. Feb 20 10:53:40 DHTL-TP1-NAS kernel: Tainted: P O 4.1.30.x86_64.1 #1 Feb 20 10:53:40 DHTL-TP1-NAS kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message. Feb 20 10:53:40 DHTL-TP1-NAS kernel: btrfs-transacti D ffff88021321bd68 0 4250 2 0x00000000 Feb 20 10:53:40 DHTL-TP1-NAS kernel: ffff88021321bd68 ffffffff88e2c4a0 ffff880265f08fc0 ffff88026fc147c0 Feb 20 10:53:40 DHTL-TP1-NAS kernel: ffffffff88e2c8d8 ffff88026fc147c0 ffff88021321c000 ffff880265d8f1f0 Feb 20 10:53:40 DHTL-TP1-NAS kernel: ffff880265d8f1f0 0000000000000000 ffff88026644b370 ffff88021321bd88 Feb 20 10:53:40 DHTL-TP1-NAS kernel: Call Trace: Feb 20 10:53:40 DHTL-TP1-NAS kernel: [<ffffffff88a4f1e2>] schedule+0x32/0x80 Feb 20 10:53:40 DHTL-TP1-NAS kernel: [<ffffffff882e62df>] wait_current_trans.isra.34+0x9f/0x100 Feb 20 10:53:40 DHTL-TP1-NAS kernel: [<ffffffff8809c8c0>] ? add_wait_queue+0x60/0x60 Feb 20 10:53:40 DHTL-TP1-NAS kernel: [<ffffffff882e7e58>] start_transaction+0x2c8/0x550 Feb 20 10:53:40 DHTL-TP1-NAS kernel: [<ffffffff882e8142>] btrfs_attach_transaction+0x12/0x20 Feb 20 10:53:40 DHTL-TP1-NAS kernel: [<ffffffff882e4d0b>] transaction_kthread+0x7b/0x240 Feb 20 10:53:40 DHTL-TP1-NAS kernel: [<ffffffff882e4c90>] ? open_ctree+0x24b0/0x24b0 Feb 20 10:53:40 DHTL-TP1-NAS kernel: [<ffffffff88082bb4>] kthread+0xc4/0xe0 Feb 20 10:53:40 DHTL-TP1-NAS kernel: [<ffffffff88082af0>] ? kthread_freezable_should_stop+0x60/0x60 Feb 20 10:53:40 DHTL-TP1-NAS kernel: [<ffffffff88a523d2>] ret_from_fork+0x42/0x70 Feb 20 10:53:40 DHTL-TP1-NAS kernel: [<ffffffff88082af0>] ? kthread_freezable_should_stop+0x60/0x60On SMB access, I am seeing a lot of errors that look like this:
[2025/02/20 16:12:33.035542, 2] ../source3/auth/auth.c:315(auth_check_ntlm_password) check_ntlm_password: Authentication for user [IMW] -> [IMW] FAILED with error NT_STATUS_NO_SUCH_USERIs IMW an account that should exist on the NAS?
You are running very old firmware (6.6.0 - released in 2016). You appeared to make an attempt to update to 6.10.10 on 19 Feb
Feb 19 2025 17:04:49 INFO:UPLOAD_IMAGE: _filename_=ReadyNASOS-6.10.10-x86_64.zip _filesize_=90385981 Feb 19 2025 17:04:50 INFO:GET_REMOTE_INFO: name=ReadyNASOS version=6.10.10 size=90783744 md5=b2f2ee74b9bbf269d449490b24b370fe arch=x86_64 Feb 19 2025 17:04:50 INFO: arch=x86_64 personality= sysinfo->personality=1 Feb 19 2025 17:04:50 INFO:UPLOAD_IMAGE: Checking file for md5... Feb 19 2025 17:04:50 INFO:CHECK_MD5_SUM: local=b2f2ee74b9bbf269d449490b24b370fe remote=b2f2ee74b9bbf269d449490b24b370fe Feb 19 2025 17:04:50 INFO:CHECK_MD5_SUM: MD5 OK! Create link in /etc/.flash_update -> .flash_update_file Feb 19 2025 17:04:50 INFO:UPLOAD_IMAGE: Write info to .flash_update_info... Feb 19 2025 17:04:50 INFO:UPLOAD_IMAGE: SUCCESSAfter that you appear to have downgraded back to 6.6.0
Feb 19 2025 17:29:10 INFO:UPLOAD_IMAGE: _filename_=ReadyNASOS-6.6.0-x86_64.img _filesize_=63207424 Feb 19 2025 17:29:10 INFO:GET_REMOTE_INFO: name=ReadyNASOS version=6.6.0 size=63207424 md5=aec396425a099a22e0fc4f43bbe6ac69 arch=x86_64 Feb 19 2025 17:29:10 INFO: arch=x86_64 personality= sysinfo->personality=1 Feb 19 2025 17:29:10 INFO:UPLOAD_IMAGE: Checking file for md5... Feb 19 2025 17:29:10 INFO:CHECK_MD5_SUM: local=aec396425a099a22e0fc4f43bbe6ac69 remote=aec396425a099a22e0fc4f43bbe6ac69 Feb 19 2025 17:29:10 INFO:CHECK_MD5_SUM: MD5 OK! Create link in /etc/.flash_update -> .flash_update_file Feb 19 2025 17:29:10 INFO:UPLOAD_IMAGE: Write info to .flash_update_info... Feb 19 2025 17:29:10 INFO:UPLOAD_IMAGE: SUCCESSCan you give more details on what you were doing here?
Feb 19, 2025Guru - Experienced User
Did you try running the diagnostic from RAIDar?
Are you seeing any clues in the log zip?
Naveenkumar001
On diagnostic. it's said some sector count in HDD 5. So we removed that 5 no HDD and restarted again ..No Improvement.
Did nt find any clues in Logs..Can u say which log file majorly i shud check for finding clues.
- Naveenkumar001Feb 19, 2025Aspirant
- 2025-02-20 10:30:36: md/raid:md127: raid level 6 active with 11 out of 12 devices, algorithm 2
Am getting this in Diagonastic screen of raidar.
- StephenBFeb 20, 2025Guru - Experienced User
What happens when you try to access the data
- Naveenkumar001Feb 20, 2025AspirantI can able to reach the data of folder...but the final folder loading many hours..and showing empty...Atleast if able to copy paste data....it more good....
I can able to reach the data of folder...but the final folder loading many hours..and showing empty...Atleast if able to copy paste data....it more good....If you want me to take a look at the logs, then upload the full log zip to cloud storage. Then send me a PM (private message) using the envelope icon at the upper right of the forum page that includes a download link. Make sure the link permissions are set so anyone with the link can download the zip.
- Jun 10, 2022Retired_Member
