DAVID533
Jan 02, 2019Aspirant
Set Up USB Device Problem
I connected a USB Flash Drive to the NV+ to test out the USB connection. I did not setup any password to access the USB flash drive. I can see the USB drive in my network, but when I try to open it wi...
- Jan 03, 2019
It's asking for credentials to access the share. It's assuming that you want to use your current windows login (which is apparently admin).
Are you using "user" security mode? If not, you should switch to that.
Assuming you are set up for user security mode, then
You could first click on the CIFS icon next to the share, and check that "allow guest access" is enabled.
However, guest access (also called anonymous access) is something that Microsoft has been tightening up on.
A more robust approach is to enter credentials for NAS-5D-83-DB in the Windows Credential Manager. You can create a user on the NAS (and use that username/password), or you could just use the admin credentials. Once you do that, the PC will use automatically use that username/password whenever you access the NAS.
There's a brief guide on how to get into the credentials manager here: https://support.microsoft.com/en-us/help/4026814/windows-accessing-credential-manager You want to enter a "windows" credential for this.
DAVID533
Jan 03, 2019Aspirant
Hi StephenB,
I am using RAIDiator 4.1.16. This is the latest firmware available for my NV+.
I created the share folder by going to front view -> Shares -> Add Shares. Enter the name "MyFiles" for the share folder, leave everything blank and press Apply. I used have a Readynas 600 didn't have this kind of problem. I also changed the admin password.
Any other suggestion?
Jan 03, 2019Guru - Experienced User
DAVID533 wrote:I am using RAIDiator 4.1.16. This is the latest firmware available for my NV+.
Correct.
Can you post a screenshot of the error?
- DAVID533Jan 03, 2019Aspirant
Hi StephenB,
Attached is the screen shot from Windows Expolor and Share Listing. As you can see I have MyFile and Media show up in my network, when I click on MyFile, it ask me for password. When I click on Media, it did not ask for password. I set up MyFile just like Media in Share Listing. I just don't know why it keep asking me password for MyFile.
- StephenBJan 03, 2019Guru - Experienced User
Thank you very much, StephenB. I added a user account in NAS, now everything is working perfectly!
