Camella
May 17, 2016Aspirant
Setting lost after power failure
I have a readynas 102 with OS 6.4.2 After configuring the shares and volumes everything works. Shut down and powering the unit also works fine But when I pull the power it goes wrong The de...
Camella
May 18, 2016Aspirant
Well I tested it a few times after clean factory resets and the device lost it's volumes every time it lost power.
And I'm quite sure it wasn't doing anything when I pulled the power cable
This sucks because now it's impossible to trust this thing.
May 18, 2016Guru - Experienced User
All I can say is that I have pulled the power quite a few times on both my RN102 and my RN202 and didn't lose data.
However users here have sometimes lost data after unexpected power cuts, and I once lost data on an old duo v1 that way - so I always recommend UPS protection.
- mdgm-ntgrMay 18, 2016NETGEAR Employee Retired
After you run into the problem can you send me your logs (see the Sending Logs link in my sig)?
Also there is newer firmware now available (6.5.0).
- HombibiMay 20, 2016Guide
I have this issue every now and then, albeit with a legacy readynas pro running os6: No disk is recognized when the nas is switched on, and I have a UPS. In my case I solve the issue by switching of the NAS and unplugging the powercord for a minute or two. In my case it is the unplugging of the powercord that makes the difference (static charge anyone?). I now it is a long shot but maybe this is the case for you too.
