Camella
May 17, 2016Aspirant
Setting lost after power failure
I have a readynas 102 with OS 6.4.2 After configuring the shares and volumes everything works. Shut down and powering the unit also works fine But when I pull the power it goes wrong The de...
kohdee
May 20, 2016Administrator
There's no reason to pull the plug on the ReadyNAS if your system is healthy. If you can't use the front panel to successfully shut the NAS off, then yes, pull the plug (but even you said you shut it off without problem).
If you pulled the plug in the middle of btrfs writing, on attempted remount, it is expecting data that never officially was written (btrfs keeps track of fs transactions), so it fails to mount.
The 10 minutes it takes to boot is likely due to a 10 minute timeout we do on the database while we're trying to figure out how to mount a file system with errors.
It's possible to force the file system to ignore what is was expecting and get it mounted. If you pop your box into tech support mode and PM your 5 digit port, I can see how bad it was and see if I can apply a quick fix.
The ReadyNAS won't try to fix a file system with errors because of the potential for data loss; that's more than I can say for Windows, which when you pull the plug on it, it will do a disk check and create problems in your file system.
May 21, 2016Guru - Experienced User
I believe Hombibi meant that he removed the plug after the ReadyNAS was shut down for some minutes. That of course is perfectly safe.
I have also found that this sometimes resolves start-up problems (mostly on Windows machines- but I think it might have resolved an issue with my Pro once). Modern devices are never really off unless you remove power, so if some system state gets corrupted (perhaps something maintained by the bios) there might be no other way to clear it.
But if the system is regularly not seeing the disk (or not mounting the volume) then there is something wrong that should be fixed.
- CamellaMay 22, 2016Aspirant
Well I don't think that removing power will bring back the settings I lost when I removed power.
However it prompted for the 6.5.0 update so I applied it
Did another factory reset + configuration
This time nothing was lsot when I pulled the power cable.
Then I waited a bit and pulled the cable again. This time I lost 1 of my 2 volumes
Nothing fancy in the logs but I'll sent it anyway
