Newsat11
Apr 24, 2016Luminary
Setting up cron jobs on OS6
I am looking for help setting up a cron job on OS6. I am using Moodle, which requires a cron job to keep it running effeciently, and i do not feel like logging in everyday to run the command manually...
Newsat11
Apr 26, 2016Luminary
Thanks for the help. I have been using SSH for a while, so it is a little late to worry about SSH. I installed some third party software that required me to change permissions and ownership on certain directories. Can you give me more information on systemd timers? Moodle provides a particular cron job via CLI, and I don't know enough about timers to now how it translates.
mdgm-ntgr
Apr 26, 2016NETGEAR Employee Retired
There is lots of info available if you search for it in a search engine and you can also see some timers already running on the NAS.
