freewun13's avatar
freewun13
Cron Jobs after NVX System Reset
Hi All,
When I got my NVX back in 2009 I started playing around with cron jobs to do a few things and they worked fine.
I just recently did a system reset and I saved all the text associated with my cron jobs etc. I have reinstalled SSH Root add on and get in fine with Putty but when I type in crontab -e I just get....
-bash: $: command not found
I dont normally have anything to do with scripting etc and I know all those years back a lot of guys on the netgear forum helped me to get it all to work.
I have tried searching for all my posts from 2009 etc and could only find from 2011 onwards.
Any help would be much appreciated and I will be saving all the instructions this time and not rely on the forum to keep all the info this time lol :-)
Thank you
  • Did you do the apt-get update again (after you modified sources.list)?
  • StephenB's avatar
    I get this:
    PRO:~# crontab -e
    no crontab for root - using an empty one
    /bin/sh: /usr/bin/editor: No such file or directory
    crontab: "/usr/bin/editor" exited with status 127
    You do need to log in as root.  crontab should be in /usr/bin
    PRO:~# which crontab
    /usr/bin/crontab
    • freewun13's avatar
      freewun13
      LIke I said...this was a long time ago so I have even less of an idea now! From Putty....
      Using username "root".
      [email protected]'s password:
      Last login: Fri Oct 19 21:36:16 2018 from 192.168.1.10
      Last login: Fri Oct 19 21:38:41 2018 from 192.168.1.10 on pts/0
      Linux NAS 2.6.37.6.RNx86_32.1.4 #1 Thu May 28 16:18:23 PDT 2015 i686 GNU/Linux
      NAS:~# cd /usr/bin/
      NAS:/usr/bin# ~# which crontab
      -bash: ~#: command not found
      NAS:/usr/bin# crontab -e
      NAS:/usr/bin#
      • StephenB's avatar
        freewun13 wrote:
        NAS:~# cd /usr/bin/
        Something is wrong here. If you have a spare disk, try doing a factory install with only that disk in place.  Then see if you get the same result.
        What firmware are you running?
      freewun13
      Here is one of the tasks I had running. Pinging various IP's around the house and then shutting down the NAS. So I had a file called pingmedia.sh and the cron job running the ping on a schedule. I just cant figure out how to create the ping media file or create the cron job....
      nano ~/pingmedia.sh
      #!/bin/bash
      # Ping Main Bed TV
      ping -c 2 192.168.1.50 > /dev/null
      if [ $? != 0 ]
      then
      # Ping Desktop
      ping -c 2 192.168.1.10 > /dev/null
      if [ $? != 0 ]
      then
      # Ping VPN
      ping -c 2 192.168.1.200 > /dev/null
      if [ $? != 0 ]
      then
      # Ping Media Server 1 Lounge
      ping -c 2 192.168.1.51 > /dev/null
      if [ $? != 0 ]
      then
      # Ping Yamaha Amplifier Lounge
      ping -c 2 192.168.1.53 > /dev/null
      if [ $? != 0 ]
      then
      if [ $? != 0 ]
      then
      # Ping Desktop
      if [ $? != 0 ]
      then
      # Ping Main Bed TV
      if [ $? != 0 ]
      then
      # Ping VPN
      if [ $? != 0 ]
      then
      # command to shutdown:
      /frontview/bin/autopoweroff & /dev/null
      fi
      fi
      fi
      fi
      fi
      fi
      fi
      fi
      fi
      crontab -e
      # m             h          dom mon dow      command
         00-59/05 22          *        *        *        ~/pingmedia.sh
         00-59/05 23          *        *        *        ~/pingmedia.sh
         00-59/05 00          *        *        *        ~/pingmedia.sh
         00-59/05 01          *        *        *        ~/pingmedia.sh
      also trying to do the shutdown with...... ~# /frontview/bin/autopoweroff & /dev/null
ProSupport for Business
