john_es
Jan 16, 2014Aspirant
Setting up... encryption?
So I turned on my new 316... 6 drives in it. Appears that it will take 24 hours to create/rebuild the volume (although I am able to copy data to it). It's currently using x-raid2 ( I didn't have a...
vandermerwe
Jan 16, 2014Master
You will need to destroy the volume, which you can do before the build is complete.
1. Disable XRAID
2. Destroy volume - disks will be wiped.
3. Re-enable xraid (you may have to do this after you have created the new volume.)
4. Create a new volume - select disks you want to be in the volume and create a new volume. In the create dialog box you will see a tickbox to enable encryption.
1. Disable XRAID
